neverexisted Posted January 23, 2018 Report Posted January 23, 2018 Just wanted to put it out there as I wasn't able to find any solid information regarding an issue where my Reuleaux would not turn on / screen would flash then turn off unless I was holding the button. I had three of these all with the same symptoms. The issue is in the jumpers they used between the battery balancer and the positive / negative battery connections. Remove those or jump them with piece of wire and all is well. I spent hours and hours on this so just wanted to share. 2
Ren.Ego Posted February 11, 2018 Report Posted February 11, 2018 This issue caused me a lot of bad words & squinting through a magnifying lens before I solved it. Well done for sharing
