2nd post here somewhat same issue  .
my previous post i was talking about mod resistance ive decided that  wasnt the issue
4 tanks  3 drippers . 50 feet of stainless steel 316L later im better off than i was but able to describe my issue a little better now . (we wont talk about the amount of juice ive wasted )
set up - triad 250 . obs engine rta  (gaia / modfather )  main 3 i use  . current build (i think lmao)  0.18  duel fused clapton 316L  28G x2 /34G .  ive done normal 26G  316L spaced none spaced to twisted to tribrades  to litterly everything i can make (from .13 ohms to .6 ohm coils )
wattage mode works fine 24.7
ive ran case analyzer which came up with widely different numbers then pre programed  (done it x3 times )  ive tried i think im on CSV file #22  currently  done everything but short an atomizer
plus side i no longer get kicked out of tC the main problem i have is as following
Fresh build fresh wick  full tank . screw her down . 400 degrees fire her up  hits like 40-50 watts  monitor shows 400 / the right wattage  etc etc works great done with my vape brake . mod sits for an hour sometimes half hour sometimes a few hours
pick it up fire it up 400 degrees (always hits the temp)  but 20 watts or the first hit will hit 50 watts and then 20 watts and no flavor . thin vapor .  (now i know the mod throttles down the wattage to maintain the tempature. but its almost like what its showing and says its doing is diffrent then what im feeling and see via vapor . right now im vaping as im typing  this with little breaks and 400 degrees 40-50 watts working great it feels like it should but i know eventually ima get that sub par vape
now when the lack luster vape happens if i crank the temp up to 480 degrees itll hit like 35 -36 watts every hit . is it just me  am i crazy?  this is my only and first DNA so i dont know if this is normal not normal somethings up or if i just have to crank the temp to hi heat to get the mod to hit the 45-50 watts that i seem to have my preferred vape. i just dont understand how for hours on end if i dont let it sit to long at 400 degrees itll hit those wattages but once she cools off its like blah ... (getting so very frustrated to the point im looking for cigs i fell off the wagon once and dont want to again been going good for 3 months now) vaped for 2 years prior .
P.s ive tried 150 wats pre heat no pre heat little preheat right now im on no preheat  well 1 watt 1 second setting 5 on the soft hard thing.
Edited by Mentalvapes
