markgill Posted June 22, 2017 Report Posted June 22, 2017 E-juice or vape juice is the liquid used in vaporizers and personal electronic cigarettes that creates the genuine vapor. It contains the real nicotine yet can be made without nicotine depending on personal preference. The vaporizer heats up the e-juice to between 200 and 400 degrees Fahrenheit which transforms it into vapor that you then inhale. E-juice or vape juice is a mixture of water, sustenance grade seasoning, a choice of nicotine levels or zero nicotine, and propylene glycol (PG) or vegetable glycerin (VG). Sustenance grade seasoning is the same type of enhancing that is used in nourishments. It is safe to consume and often, quite delicious. Propylene Glycol is a substance that is used in numerous flavorings to help distribute the taste and any sustenance grade seasoning evenly all through the fluid. PG is used in vanilla extracts, sustenance shading, and in different types of medicines. Vegetable Glycerin is a vegetable based fluid that is thick and sweet. VG and PG make up around 90% of the contents in e-fluid with nicotine and sustenance grade seasoning making up the remaining 10%.
