Hi all,
I upgraded to a DNA 75c mod from a cheap innokin coolfire and I'm a bit baffled at the settings for my Ni200 coil which, of course I run in TC mode. The vapes I'm getting with the following settings feel really weak and comparatively smaller cloud compared to my old mod:
punch: 5
preheat: on
Power: 60w, temp: 242C
Firstly what's the difference between Preheat wattage which I saw in escribe, and the main wattage on the main display?
Does anyone have any recommended settings for vaping with Ni200?
secondly, when I go into diagnostics, I get readings of 0 for Amps, Volts and Ohms - is this normal?
Thanks!
Normally in Ni200 i run these: (i would use as a base)
Power - 30W
Temp - 520F
you will need experiment with power and temp to find your sweet spot. I would recommend only moving 1 at a time (Power or Temp) up and down..
Temp is the main control but if the power is to weak it will not be able to achieve your desired temp.
