DonnyX Posted August 7, 2015 Author Report Posted August 7, 2015 When I fire my Hana V200 my voltage works fine but when I fire my Opus200 the voltage is always set at 12.3 or 12.4 no voltage reading at all. Is there a setting in E scribe to fix this and check what it's reading?Edit: Nevermind I found the settings in Escribe I forgot everything is able to be configured.
clborden Posted August 22, 2015 Report Posted August 22, 2015 So what did you do? Was there a voltage setting or something? I'm having this exact problem with my Opus200, but I'm on a Mac. And of course, eScribe is PC only.
scoopy Posted August 22, 2015 Report Posted August 22, 2015 Ahhh.....its under the screen tab.....The section on the top left (sorry I'm not lookin at escribe right now) set all the selections in the drop down to general or default..... yours is actually showing up battery total voltage right now instead of the output voltage to the atty
clborden Posted August 22, 2015 Report Posted August 22, 2015 Oooohhhhh....so it's only displaying the battery's voltage. Not the output voltage. I was avoiding my Opus200 because I was afraid I'd fry it. That makes complete sense. Thank you very much.
DonnyX Posted August 23, 2015 Author Report Posted August 23, 2015 Make sure you keep up with the firmware there has been a few updates. You can experiment with the settings and if you feel you did something your not sure of you can reset the settings to default.
