"If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'.  Resistor link
Above the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board.
That will give you what you want."
the small solder pads are small circular?  just need a diagram because I can't imagine it.
