scoopy Posted October 5, 2015 Author Report Posted October 5, 2015 I have ran case analyser twice now with the room temp at 70 F and after running it the device monitor always shows around 65 F Any ideas? Does every ones read accurate exactly after running the analyser or is it off?
Spirometry Posted October 5, 2015 Report Posted October 5, 2015 I have a Vaporshark and a cnc 1590g, on both devices the room temp is around 10° too high.
scoopy Posted October 5, 2015 Author Report Posted October 5, 2015 Have u ran case analyser .... These results are after running case analyser It gets to 65 after letting device monitor on for awhile....It steadily drops from the time I plug it in.....actually board temp drops to but not that low
Spirometry Posted October 5, 2015 Report Posted October 5, 2015 I have run case analyzer multiple times on the 1590G. On the Vaporshark i am using the preconfigured numbers.While we are on the subject, anybody know what °F/A is?
scoopy Posted October 5, 2015 Author Report Posted October 5, 2015 Have u let it sit on device monitor......it takes a while but if u don't care let it sit a while with device monitor up and see if it keeps decreasing til it steadies I think it means degrees above ambient temp
Spirometry Posted October 5, 2015 Report Posted October 5, 2015 sitting on device monitor (charging) my temp falls to about what my actual room temp is.
scoopy Posted October 5, 2015 Author Report Posted October 5, 2015 Hmmmm.....have u kept watching it for quite a while....It takes a bit and goes down like .01 at a time but mine finally rests at about 65 when my room temp is 70.......I ran it on a board I had to rma because of a resistor that got knocked off but I guess I'll try it again on this new board......I have the settings from the previous chip uploaded to this one and it's saying the same as last chip......maybe running it again on this chip will correct it though
