tehdarkaura Posted October 28, 2015 Author Report Share Posted October 28, 2015 So i get this message when I try to test my battery -- I am using two 1 ohm 100 watt resistors in parallel not sure what the issue is -- any advice would be appreciated.I am using a laptop and a longish usb cable... not sure if that could contribute to this sort of issue. Link to comment Share on other sites More sharing options...
tehdarkaura Posted October 28, 2015 Author Report Share Posted October 28, 2015 I used a different USB cable and it worked fine!Thanks! Link to comment Share on other sites More sharing options...
Niet Posted May 7, 2018 Report Share Posted May 7, 2018 (edited) Hi, I got a new squonk mod with DNA75C, same issue whatever the usb cable used. EScribe version 2.0 SP 15.1 INT Firmware 1.1 SP 33 INT if someone knows how to perform a battery analysis, could he share how to proceed ? Regards Edited May 7, 2018 by Niet Link to comment Share on other sites More sharing options...
SManBoris Posted December 25, 2018 Report Share Posted December 25, 2018 It was several times. Replaced the wire, but the launch from the second time only. Unclear. Link to comment Share on other sites More sharing options...
lazybones Posted November 10, 2019 Report Share Posted November 10, 2019 I had the same issue, it was resolved by; 1, plug mod into e-scribe, 2, turn mod on (while plugged in) 3, measure resistance of the test atomiser (also while plugged in) worked fine for me after that. Link to comment Share on other sites More sharing options...
