JABBER Posted March 6, 2017 Author Report Posted March 6, 2017 Hello everyone, I have a problem with my temperature control in SS316L. When I push the fire button the temperature rises and displays rapidly 41297 ° C before resuming the temperature rise. Have you got an idea to solve this bug?Thanks
UKDTweak Posted March 7, 2017 Report Posted March 7, 2017 You either have a bad connection or have not set the base/resting ohms properly, check your leads are tightly trapped and the 510 pin on your atty is not loose, then leave to sit and refine.
JABBER Posted March 7, 2017 Author Report Posted March 7, 2017 Tanks, I will try everything this evening and I will tell you if it's working.
JABBER Posted March 8, 2017 Author Report Posted March 8, 2017 Hi, problem solved, I have not set the base/resting ohms properly .Thnaks for your help
