Mac Posted July 21, 2015 Author Report Share Posted July 21, 2015 Is the Battery Ground Common to the Out ground? If so is it possible to connect the high current ground direct from the battery to the 510 or would it still need to go through the board?Mac Link to comment Share on other sites More sharing options...
John Posted July 21, 2015 Report Share Posted July 21, 2015 They are common, but remember the board itself needs a ground connection too. Link to comment Share on other sites More sharing options...
malcbzt Posted July 22, 2015 Report Share Posted July 22, 2015 is there explained like I'm five how to solder battery connection, balancing connector from the dna200 box and 510 ? I will use referance case Link to comment Share on other sites More sharing options...
Mac Posted July 22, 2015 Author Report Share Posted July 22, 2015 Thanks, John Link to comment Share on other sites More sharing options...
jgstrings88 Posted August 2, 2015 Report Share Posted August 2, 2015 malcbzt if you need soldering instructions on board to 510, Balance conn and ground connections, I would advise starting with something else than this somewhat pricey, very nice regulator. Lots of good soldering tutorials and practice with these particulars like 510 connectors. This definitely isn't a first mod type build. If I'm mistaken about what you meant sorry. Link to comment Share on other sites More sharing options...
Jef Posted April 1, 2017 Report Share Posted April 1, 2017 This post was helpful as My cell orientation will take advantage of the boards ability to acceptance cell negative at location other than overcrowded balancing location. Thank You! Link to comment Share on other sites More sharing options...
