Darth vapes Posted May 9, 2017 Author Report Posted May 9, 2017 As some of you may know the o rings are really loose...i found that if you use the ONE spear o ring for the airflow barrel it works nice and tight without being too tight...take the top o ring off and replace with the barrel o ring...lube with juice and let it settle in...leave the bottom o ring on.
