ardentBarbarian
Everything posted by ardentBarbarian
  1. I think the message shown when the coil overheats could be a bit more generic like "Antiburn protection". A lot of people see fill pod and only look at how much e liquid is in the tank and don't realize that it might only be about their wattage airflow setup. Some clear info provided by Oxva in the box the device comes in as to the reasons why "fill pod" may be displayed would be very helpful.
  2. I've found if the wattage is too high and the airflow is too low, the coil overheats and says, "fill pod" despite there being enough liquid. All fill pod means is the coil got too hot because a) too high wattage and not enough airflow or b) there really isn't enough liquid, causing the coil to run too hot. You can experiment with the wattage and airflow until the message stops popping up.
  3. Does anybody else here miss the .5 watt increments that are possible on other Oxva Xlim devices? Ironically, you can change in .5 watt increments until you hit 10 watts and then it's just whole numbers. Can this be changed via Escribe?
  4. Weirdly, I found that opening the rubber cover, closing it and then drawing on the pod a few times before inserting it again, made this go away. The problem is I have to keep doing it once in a while. I guess that would mean it has to do with the air pressure inside the pod?
