Exro
Exro last won the day on October 23 2025
Exro had the most liked content!
  • Full Name
    Chris
    Austria
    DNA60C Stubby, 3D Printed DNA250C (printed by myself)
Exro's Achievements
  1. Oh sorry yeah i should use search more but i guess it is a bug then, thanks
  2. Hey guys i have a problem, I made a theme and i used a gauge with 2 pictures that show a bar thats getting fuller for boost in Watts Mode. Now if u change the bar and everything seems to work. Though when i fill the bar fully and i download the settings from the device the boost is set to 22 instead of 11. And if i set it back to 11 and download the settings to the mod the bar is only half filled. I tried changing the size of the bar to like half but that didnt seem to change anything i could still adjust it up to 22. And i cant find a setting to change that anywhere. What am i doing wrong? Is this a bug? <3 Exro Edit: Its a theme for a DNA 60C.
  3. Version 1.0.0
    709 downloads
    Hey guys i decided to take the Digital theme for dna250c etc and make it for the dna60c. I think it came out pretty good, i am a wattage vaper though so i cant tell if i did everything right for temp and replay stuff. I tried to get it as close as i could to the original and i hope you guys like it. This gives way more info and customization options right on the device like compared to the standard profile i had on my Stubby. Lock screen shows puffs since last reset as i like to keep track of my coil life when i put in new coils in my boro. And under Puff Info you find your Last Puff settings and the total puff count overall. I KNOW THE TEXT IS SMALL FOR SOME THINGS (but otherwise i would have had to change a lot of stuff and it wouldnt fell like the original theme) So not for people with bad eyesight, i can read everything just fine though and my vision is pretty normal. I am eager to get feedback, so please tell me if there is stuff to fix so far it works perfect for me in Watts mode. Powerbank feature and all the usb info and settings and stuff all work. ❤️ Exro €:; I forgot to thank SirTimmyTimbit and gremlinn for their amazing work on the original €€: Uploaded some basic as screenshot as it is 2 in the morning as i finished this up to this point. Better screenshots coming soon.
  4. Nvm i tried another board from a paranormal 250c and it seems to work normal, must be that other board is broken
  5. So i harvested a board from a triade 250c, which is 3s config. i rewired it for my 3d print project to be 2s and i changed it in the settings as far as i can tell. When i plug in the board to usb everything works normally and device monitor shows me both cells at around the same voltage level. Now my problem is if i unplug usb nothing happens, its just dead pressing fire button does nothing no LED or screen working. So what am i missing?
  6. Oh wow havent thought about that i thought i could still configure it without batteries attached, sry about that then
  7. Hello guys i recently ordered a DNA100C Board to use in a Project of mine which is to Design and 3D print a mod. Ok today the board arrived, i plugged in the screen and connected it to my PC (Back then WIndows 10) the red indicator LED lights up and the screen flashed on for like 100ms, it showed proper stuff from what i could see and the PC made the USB device connected sound. In Escribe i am at the screen where it says to continue please connect a device, during the time where the screen flashed it also detected the board but it immediatly disconnected. I tried multiple things and in the end even reinstalled windows to windows 11 because my old windows installation was pretty bad. Ok then i also tried it on my macbook same behavior screen flashes on for a few ms and pc recognizes it and iimmediiatly disconnects again. Then i installed windows 11, now it wont even flash the screen or connect for a short time, now it just shows i need to connect a device. I tried multiple cables aswell and since it did find the mod on windows 10 and my macbook i think i definitly got a data cable i am using- Welll i am trying to get back to where it atleast connects for a second on my windows 11 installation now, in the meantime can anybody help me resolve this issue?
