Gnostical
Gnostical last won the day on April 21 2024
Gnostical had the most liked content!
Gnostical's Achievements
  1. Thanks for the help so far, after cleaning the contacts and re-adjusting the battery cap, it stayed until 25% battery before dropping off. Not perfect, like how I used to get it to 10% before dropping but still, good enough that I'm happy with how it is now. Here's it with the battery at full charge and here it is at 25% when it started saying batt down. I noticed it kept climbing in charge when not using it to the point of gaining almost 10% charge within minutes, then taking a couple puffs, it quickly drops back to what it should be. Not overly concerning but just something odd. It was having a lot of difficulty reading the battery charge correctly compared to before
  2. Why 18650 if I'm using a 21700? I'll set it back to 2.75, but what would happen if it was lower? Oh also, and I'm using it single coil 0.20 ohm at 35w. Typically chain a few puffs then set it down for 5-10 min. The battery goes into low batt mode after an hour of usage.
  3. I just cleaned it as thoroughly as possible with cotton swabs and 99% iso alcohol on both ends that the battery touches. I adjusted the screw on the cap to fit as tight as possible. I was poking around the escribe software and the cell soft cutoff range was I think around 3.5V default and the type is set to 18650 and it won't let me click it to change to 21700. I just moved the cutoff to 2v, would that help at all?
  4. Hi, I've been using my DNA100C every day for about 9 months now, but lately, in the last month or 2 I've been getting this issue where the battery charge indicator isn't even down halfway and starts getting weak puffs and says "batt down." I figured the batteries were dying, 2 Samsung 40T's, both do this on this mod. I don't have another 21700 mod to test. I just picked up 2 more Molicel P45B's and they do this too at around 60% charge despite being completely new. If I immediately change batteries it's fine until I hit that dreaded 60%. This wasn't an issue when I first got the mod, it might start saying batt down at 5% or 10% charge at first, but it's starting to do this sooner and sooner despite having plenty of charge left. What could be causing this? The mod is a ViciousAnt Primo. Thanks
