db151mod
db151mod's Achievements
  1. Hi guys, does anyone have the USB card file available in cad or .stp or .step? . Unfortunately I also contacted the team but they only sent me the one for the main card, not the USB. Thanks a lot to everyone
  2. Hi, yes you are DNA 60
  3. and yes then that will surely be the problem, the internal battery is not very charged, because actually now it does but not always, it alternates a bit, so I assume it is starting to charge. A thousand thanks
  4. Hi guys, it happens to me that my DNA configured now, when I go to disconnect and replace the battery it doesn't keep the preset in memory, it always goes into mode to choose the profile, there is an option to keep the last one in memory preset selected? Thank you
  5. ok perfect, thank you very much
  6. Hi Wayneo, thanks for your advice, so can I feel comfortable with the 20 GA? , that I won't have power drops? A thousand thanks
  7. Hi guys, if in DNA 60 instead of putting the recommended 18 AWG wire I'm putting 20 AWG, has anyone tried it? Do you notice any drops in performance or heating? What have you noticed over a long period of time? And what problems might I encounter? . A thousand thanks
  8. it was just to insert some info, I happened to download profiles, and I see that that field is populated with info or images, and I therefore wanted to insert some info
  9. Hi, a question, when I go to double click on the .ecig file from the settings installer screen, I would like to understand how I can modify it? I didn't find any system, I send screen below. Thank you very much
