TLP DESIGN
Everything posted by TLP DESIGN
  1. Hello, I need to repair my dna vt box 250c, how can I do it? I need to replace the chip with the usb charge part. Thanks
  2. Now is fully charged but the display still says 51%.... After 8 hours of charge
  3. Yes, it doesn't work again the percentage was 51 (after I'm charging it since 10 AM) and now it's 45%.... have no idea why it doesn't display correct percentage
  4. Or I can maybe use this charger I bought with the box 3 years ago? it should be good I guess
  5. I added another log file (while firing), now the percentage is 41% and when I plugged in was 34% probably the reset and YOUR VERY HELPFUL answer fixed the problem. I can't know it cause now I'm goin to wait for 100% charge and then I will use it to see if it drops again from 100% to very lowest percentage. Another question you experts maybe know...which is the max output of charger I can use for charging the battery? can I use a 45W supercharge with 5V and 4.5A output in your opinion? Or probably is always better to use the Escribe software cause I red that it gives you the best charging mode for your box? THANK YOU VERY MUCH GUYS, I attach the pic of the charger with the specifications. log_4.csv
  6. yes I just did it and now it says 34% percentage but this is not possible cause the battery is charging since 06 AM this morning :(( but at least now I can use it the problem is that I will never know when batteries are low...
  7. Hello, first of all thank for your answer. The problem is that I did a reset and now is even worse cause It keeps saying "check battery". which one I've to choose of this? I selected 250W 3 cell cause I thought it should be this for the 250C VTBOX. it's 200watt 2 cell or 250w 3 cell? Unfortunately I don't know anything about this box.
  8. Hi guys. first of all sorry for my bad english. I have a problem with battery percentage which is not shown properly. I left the box on charge for at least 5 hours, it never reaches the 100% (in the past I had no problem with it.) The percentage drops from 54% after 5 hours charging to 8%, this happens more after I puff. I have no idea how to use Escribe software to make correct settings, I use the box on Watts profile, 0.2 Ohm and 70 watt. I've seen there is a cell option (I have 2) and I can change it but I'm afraid to do it, I don't want to make troubles... I attach some screenshots, thank you very much for your support. EDIT: I've done a settings reset and now it says "check battery", battery is plugged by USB but it's not charging....if I click settings > atomizer > measure it does nothing... please help I love this product and I don't want to change it... :(( log_3.csv
  9. Version 1.0.0
    68 downloads
    SCREAM - GHOSTFACE - DNA VT BOX 250C - - - BY TLP DESIGN (ENG)
