Marco234
Everything posted by Marco234
The cover thats on the front of it that can be slotted out with another one....has screws on it that allow this is there a way i can get a replacement cover for the front of the unit? I am asking because i wanna change it with the clear cover--the cover thats on the green model...so i can see the led light that the fire button gives off. Any help?
Any good triple x 2x700 mods that are decent?
Marco234 replied to Marco234's topic in Modders' Forum
I got the 2800mah molicel one 4 of them -
oh my bad forgot the link that was referring to the batteries i was talking about...do they have any good 18650 batteries like these ? https://www.18650batterystore.com/products/molicel-p42a My mistake lol -
are there any batteries that are 18650 that are good and have as much MaH as this ? Also what does "45A" mean again? sorry to ask.... -
do they have a quad 2x700 version? also what happens if you drop it... will it get all fucked up or stay pretty stable -
used rebel and now I'm using boxer and it's not as sturdy as I thought after normal use.... I could use a better mod that doesn't break after nothing the main problem with the boxer is with the button... it literally just popped off... with normal use... any help?
yea .....im a thinker type.....i question things to the T so its hard to b like.....ok what am i using without wondering how it even works..Something that drives me deep into my mind sometimes LOL
jeez who knew high tech mods could be such a pain to understand LOL
i think i understand more now, just not too well.. well thank you for the help
what would you say is more effective at upping the power punch or warmth or both?
i see, so its not defined well, but either way it makes the mod do something different....i guess i will experiment and see whats up since warmth isn't clearly defined
sorry looking at this is akin to me looking at statistical graphs which im not good at....and yes i was changing warmth soley and nothing really occured. Earlier you said warmth soley changes the temperature part of the mod not the wattage part....but all i wanna know is by how much does the temperature (as you said before, warmth associates with temp) change by each number up. Thats all i am trying to say. I am sorry.
dude....as i said before....i did this....no change occured...i feel like im not asking a lot.
I have watched those vids That picture just says it increases power,,,,power as in watts or temp? if its just raising watts how is it literally any different than punch. Its not that hard to get my question. What. Does. It. Raise. Watts or temp or some other variable. Power to me always refers to watts. Idk if you can't understand idk what to tell you
im still not understanding what warmth raises....and by how much does it raise. I know punch raises wattage. You said earlier warmth raises temp.....but by how much per number .....eg.....1....2.......3 etc. sorry to be rude
i read this but i am not sure what warmth actually modifies,,,,watts or temp? and when it goes up by 1 increment is it going up by one degree or watts. Thats all im trying ta ask mahn
i tried to find out but it didn't help much.....can you just try to explain to me but what each addition to the warmth setting does? in terms of temp? Sorry to bug you, i don't really know where else to turn
I see.....so does each push on the warmth gauge basically ramp up the temp one degree so in other words cold coil temp (usually shows as 70F) is how the coil is when its not at use?
-is it preheat in terms of wattage or temperature? -yes but what is the point of knowing the cold temp of the coil
hello?
also what is atomizer > coil > cold temperature What is the point of that ? Still a novice greatly
also what is warmth on the mod mean....does it have to do with watts or..
hmm it does move a little while firing i just noticed this shit too wow But yea should i up the punch or boost up the preheat wattage at all?
I see i have a ss316 .3ohm coil....so like what would be a good temperature to stop at ? because i am up at like 450 and im getting weak ass hits with live wattage level being at 15w almost when i set it to like 40. this is not for preheat btw..... also is preheat (wattage or temp) basically the same as the punch/boost feature?
so for the temperature control settings on my mod when i am in ss316 temp control mode for example.....it shows two fields one being the temp you can set the atomizer at.....another being a wattage field which i just thought was normal wattage until i discovered its a preheat watt function.....what is this preheat watt function and should i set it to just normal watts on my device theme? Should i have wattage, preheat wattage, and temp all three on the temp control profile? Please help this is all sorta hard for me to understand and basically get why its important and how it all works....other questions are should i lock one of the fields like tempetature ? idk...please help ! lol
