Peat
  • Full Name
    Pete
    Australia
    Hyperion DNA 100C
Peat's Achievements
  1. Thanks so much for the fast reply and helpful information BillW50
  2. Thanks BillW50 Yeah I do recall that it was a Arctic Fox firmware mod. I could be wrong but I believe the autofire allows you to just press the fire button once without the need to hold it down while the coil heats up. I’m waiting on a new atomiser from Divine Tribe (DC Gen 2) and this autofire mode would be great for it.
  3. I’ve watched a video of someone using a eleaf pico 75w mod in autofire mode. It also showed the temperature climb in real-time on the screen. Is there any program that can be used to emulate/replicate or copy this function on the DNA 100C? If so where can I find it? thank you
  4. That’s great to hear you’ve been able to solve this issue Nils81! Are you able to do a step by step guide on how you reset your device?
  5. When I first powered up the device it had the default evolv theme, black background white text, which was ok but I was keen to put the DNA 100C (Lost Vape Hyperion mod) through its paces and change the theme to something more custom. The theme I chose was Pro Vapers by member aMirs. It worked great but I got greedy and wanted to change it to another one. This time I went with The Giant v9 with the Darth Vader Lock Screen theme. This is when the inverted colours issue occurred. I tried to reinstall the default theme however the colours reminded inverted.
  6. Will do thanks for the advice.
  7. I’m not sure why you say there is no issue? The theme I chose and downloaded from the forum site had a black background with white text however when uploaded to my device those colours are reversed, white background with black text. I’ve tried other themes and those with multiple colours schemes, once inverted, become almost impossible to read clearly. I’ve reinstalled default theme and the inverted colour issue persisted.
  8. I’m wondering if anyone has worked out how to fix the inverted colour issues that others have identified?
  9. Hey pinux13 or anyone could you please show where in Escribe you select “mechanic” I’ve not been able to find it anywhere.
