vape vape
Everything posted by vape vape
  1. Micro usb.
  2. It is not recognised when the battery is removed and tried. Other dna60 devices are recognised, but only one is not. Is there a chip fault?
  3. I bought a dna60 device. When I connect it to the escribe, it charges but does not recognise the device. I use the cable for transfer. Trouble.
  4. I would like to reproduce it on my device but can't.
  5. What do you mean? A little more detail would be helpful.
  6. vape vape
    View New coil
    When does the NEW COIL appear as shown in this image? I have been using DNA60 for 3 years and have never seen such a setup.
  7. This is DNA 60. I get this screen and the wattage keeps dropping and I can't operate it.😭
  8. I get this screen and can't operate at all. What is this screen?
  9. 0.03 resistance drop and stabilizes at the low end Sorry it took me so long to get back to you, thanks.
  10. 0.03 resistance drop and stabilizes at the low end Sorry it took me so long to get back to you, thanks.
  11. This is the mod screen.
  12. This is the case for all coils. But it doesn't happen with anything other than the billet box.
  13. Hello! Thank you for yesterday! Dry Fire is running properly. The other mods are stable, but only the billet box has a slight drop in resistance on the first firing.
  14. For some reason, when I press the button to heat it up, the resistance drops a little. Normally the resistance should go up when heated, right? After it goes down, it stabilizes, but why does the resistance go down a little only at the first heating? I'm using Kanthal wire. And I use it in orthodox power mode.
  15. I'm looking! The billet box is 0.07Ω more expensive than other DNA mods when built with Kanthal.😭
  16. Thank you! Does your billet box also have a jump in resistance?
  17. Thank you very much! The resistance of the billet box adapter is high. Is it dangerous to roughly adjust 0.02 with that in mind?
  18. I'm sorry. I don't understand. What is this mod resistance item for?
  19. OAM reader 0.7Ω Other 3 DNA boards mod 0.72Ω Billet box 0.79Ω
  20. My billet box shows a higher resistance than other DNAmods. For example, other DNAmods have a resistance of 0.7Ω. With the billet box, the resistance is 0.77Ω, which is 0.07Ω higher. I want to compensate for this 0.07. I only use power mode.
  21. For the mod resistance field in escriae, do I just enter the number after subtracting the internal resistance of the mod? What are the settings here?
