dabberbid
dabberbid's Achievements
  1. I was able to clone my Mirage to the Vicious Ant; thank you Wayneo! Now I just need to figure out how to change the wallpaper (only) back to the Vicious Ant paper... But that's less important to me than the dynamic temperature. Thanks again. Helping out anonymous strangers is truly above and beyond.
  2. THANK YOU! I'll try that after work and report back. Really appreciate it!
  3. Thanks very much, I really appreciate it. I'll try clicking on one of those squiggly lines to see if the Nickel 200 screen comes up. Is that the right direction? Also, I tried copying my Mirage theme over last night, but it didn't work. Here's what I did. What part did I screw up? First, I loaded the Mirage settings. Second, I saved the settings by going to FILE and then SAVE AS. This saved a dot ECIG file. Then I disconnected the Mirage and connected the Vicious Ant. I then tried to load the dot ECIG file so I could save it on the Vicious Ant. But the dot ECIG files were greyed out when I tried to select the one for the Mirage. Did I not save the correct file? Of did I save it wrong somehow? I've heard there's issues with saving themes/profiles (not sure what the difference is) for Escribe; is that the problem? I'm not yet totally frustrated with Escribe, but I'm getting there. THANKS!
  4. Thanks, I think we're getting somewhere, but I'm still not getting it. If you look in my post above, you'll see a photo my my mod's screen with Nickel 200 temperature control. Note that both watts and temperature are displayed on the mod screen. Below is pic of my Escribe Theme Designer screen for the mod. There is only one small screen icon on the right of the photo below listed as "Main Screen" and it doesn't appear to have anything to do with Nickel 200. Further, although the small screen icon on the right of the photo shows both watts and temperature, like the actual mod screen does, the large *working* screen on the left shows only watts. I can't even click on any temperature to change any settings, because there's no temperature to click on. Can you "please* help? I'm not getting anywhere by myself, and I'm having trouble even understanding what Escribe and Theme Designer are showing me. Where is the screen for Nickel 200 temperature control? How do I get to it? Once I find it, what do I do to keep the temperature updated? THANKS!
  5. Thanks, I appreciate it. Who's Wayne?
  6. Won't that just update the watts?
  7. Thanks. The size of the number isn't really the issue though. The issue is whether the temperature updates in real time when firing. Here's what the screen looks like now. The temperature remains fixed when firing. I'd like to set it up like my Mirage, which displays the actual temperature in real time during firing. Does unchecking "temperature-dominant" do that?
  8. Thanks. I'll try that later today. That will cause the mod to update the temperature while it's firing?
  9. Thank you for both of your responses dwcraig1! I see the ohm re-read now, thanks! For the dynamic temperature display when firing, exactly what do I need to change in the screen you provided above? I can't figure out what should be changed. Thanks again for your help!
  10. I'm willing to fiddle around in escribe, but only if I have some direction first.
  11. I have a vicious ant 75c, but the temperature and watts do not dynamically display when firing in temperature mode (nickel 200). How can I get them to dynamically display? Also, it doesn't seem to be able to re-check the coil ohms. Is there something I'm missing? I scroll to ohms and hit the select button, but nothing happens; there's no new screen with a re-check ohms option like there is for my Mirage.
