Pigsy
  • Full Name
    Simon Turner
    UK
    Prisma DNA75c - DNA 200 - DNA 60 Self Build
Pigsy's Achievements
  1. Thankyou for your replies @Wayneo @dwcraig1 now ive calmed down and went searching the forum i read a post about escribe cant connect without a battery connected, the only thing i didnt try and low and behold she lives. Least i know my connections are good after resoldering everyone 😄
  2. Hi all I making my own mod have soldered everything where I believe it should be using a 2amp charging board for the dna60c, plugged it into escribe it detected the board then said no device connected. Have tried several USB cables but no difference, it connected one time started to up load the settings and stopped at 6% and wont go no further and escribe just has the spinning wheel I can't even Close escribe. I'm using windows 10, Any help would be appreciated as I am gutted was the last thing to do to complete the build. Have attached a pic below just incase someone can see something I've missed Cheers Si
  3. Im not the best person to be able to explain a problem and should of put in more information, i have heard of a cold solder joint in the past, hoping its not that. i have attached a picture ( hopefully it works) of the mod. Shame because its a great mod. Thank-you for your time 😊 C0291407-B97A-4676-AE09-C50C68A7D769.webp
  4. Yes i dowloaded the theme so i had replay if i wanted to use it but in the watts profile i use for n80 i disable replay, Sorry for the confusion will edit post.
  5. I don't have replay turned on in escribe for that profile !
  6. It goes in one full turn then starts reading ohms, reads 1.2 ohms and all the way in it reads 1.076
  7. Ok i done the atomizer analyzer before firing it.... Ohms 1.067 Raw Ohms 1.071 Mod Resistance 0.004 Room Temp 67.41°F When fired showed the check atomiser twice and now works fine, hope this helps.
  8. I thought it best to do it before as thats when the problem is. Yes this has happened from day one, only had it 6 weeks. Thought it maybe the theme so changed it as i wasn't keen on it anyway.
  9. Will do this when i get home from work, should i do this before i fire the mod ? Sorry don't know how to post findings but will have a look.
  10. The atty is a 24mm Dvarw The coil is a MTL clapton all ni80 (pc coils) Sorry how would i find room temp for mod & atty ? Battery contacts are all clean.
  11. I recently bought a Prisma DNA 75c, i have downloaded the Evlolv replay theme on to it. My problem is once it has locked i unlock it and everytime it shows check atomiser from 2 to 5 times then it will fire and be ok until it locks again. I have checked the atty is tight and tried other atties aswell but still does the same thing, I downloaded another theme to check it wasnt that and i am now stumped. Any help would be much appreciated please.
