Budgie
    dna250 & dna250c
Budgie's Achievements
  1. To be honest, and I apologise, I never tried it in TC for that long to be able to state it was working fine before I started trying other coils. The MTL Clapton wire is the only non SS wire I have, so I think I’ll put it aside and just use the SS round 28ga wire Ive used to get the 0.7ohms I have now. It’s working fine in Replay, so I really can’t see the benefit of trying to get a higher resistance than I have right now. Your assistance is greatly appreciated, many Thanks.
  2. Thanks for your replies, the 1.15ohm coil is MTL Clapton Nichrome 80, six wraps not spaced, and the 0.4ohm coil is SS, six wraps non spaced. It’s weird because after I wrote the post, I was messing around with coils, and it seems anything up to 0.7ohms works fine in replay, but go above that, and I don’t get the Save option. The Nichrome 80 coil seemed to work fine in TC. Right now I’ve got the 0.7 in there working Replay mode fine, so I’ll check the resistances next time I change the coils. Thanks to you both for your help.
  3. When you use Replay Mode, does it have an upper resistance level where it will not work? The reason I ask this is because I have an mtl rta with a coil value of 1.15ohms, and it does not allow me to “Save”, yet it does with the same rta with a 0.4ohm coil in.
  4. Thanks for the reply, it’s the Punch adjuster, I was adjusting it then going into Atomiser, and you could see the change in there. Mystery solved.
  5. I’ve just bought a Hammer of God 400c, and was curious what the battery icon in the bottom RH corner is about, and what it’s function is, there’s nothing in the manual about it. It is adjustable from no green all the way up to red.
  6. Cheers for that, it’s what I’ve been doing, but just wondering if you could change it somehow.
  7. In Escribe the default settings for 2 batteries is Li-on 18650, can you change this over to 20700 and 21700 Li-on battery types, or does it matter?
  8. Thanks a lot for that.
  9. With the Evolv 250C (and 250), is it advisable to charge the batteries externally, as i do with my other mods, or do these boards have a superior charging system to allow for internal charging?
