Version 1.0.0
277 downloads
I'm fairly new to DNA Chips and at present I am not a big user of temp control.
The factory presets on the ODIN DNA 250c I found to be heavily based around TEMP control and had a lot of presets on that weren't suitable for myself as a wattage based user. So I modified the presets to current personal tastes and thought I'd add it incase anyone else was "in the same boat".
Below are a list of the presets with an outline of what they do :
Kanthal : Standard "Watt" mode with no punch or boost
Watt Punch : Standard "Watt" mode with a boost of +2 and Punch enabled
Watt Boost : As above, but with Punch disabled
Watt Replay : Standard "Watt" mode, but with Replay enabled
Watt Boost Replay : Standard "Watt" mode, but with a boost of +2 and Replay enabled
SS 316 : Standard Odin Default
SS 430 : Standard Odin Defeault
Replay : Standard Odin Default
*Starting "Watt" amount is preset to 20 on all modes except Kanthal which is preset to 30. This is to avoid any accidental coil damage.
*No coil ohms or temperatures have been pre-set for the same reasons as above.
I hope this helps somebody out at some point. I will be uploading a "matching" theme as I have tweaked mine ever so slightly and found it makes a huge difference, without going overboard.
Vape safe everybody
