Lucasammy
Everything posted by Lucasammy
  1. @Pphish im using Kylin v2 from vandy vape.
  2. Yes, can be that the problem ?
  3. with onlt one coil and a little bit of more resistance its works. that should work on only viable coils. i dont should be like that... thats why im very very intrigued with that situation.
  4. ive tryed to change to dubious coils! its works but... Why? these is not a dubious one... i think kkkkk
  5. When i put some coils kind a "higher resistance" then that it works! The print i post is of a dual coil 24g x2 wraped with 40g fused clapton ss316l. Using ss316 material on mode "replay" With replay enabled... so now i changed to only one coil and i just wicked. THE SAME COIL. I just remove one of those and re wicked... check it out
  6. damn!! no way thats happening ! i both as ss316L! WTF is going on here? K1 and NICHROME should show any change, right?
  7. check it out man @dwcraig1
  8. exatly im geting to little change. is that what you mean right? but if i heat it more i think ill get a dry heat. what ever the mod dont alow me to go any higher because of the temperature... and i fell that these build its getting to hot but... i shuldnt! ill post some device monitor in some minutes. thnks so mutch for the help man!
  9. its giving me the chages. when i start to heat its starts at 0.080ohms and gets pretty fast to 0.089 something like that. ill give a try for wats material. ill let you know
  10. ss316 L
  11. its all on. Replay on this profile, i got theme with replay too. but it dont recognise. I have wait to got cold resistance to measure it and... nothing. im working with 0.080 ohms. thanks for all answers!!
  12. thanks for the replay. I think its working on TC but it dont recognize as a replay coil.
  13. Sup my friends im kind new on these replay and dna situation. I would like some advice from you fokes. Whats the lowest resistance build should i run to work with replay? What you guys see bad and good to run a really low resistance build. (talking about 0.08 ˜ 0.07 ohms) Do you have some advice for me?
