HxChris
Everything posted by HxChris
  1. Thank you, hopefully this will do something!
  2. P.S.: Apologies if this belongs in another sub-forum, but I don’t quiiiiite feel like this is a bug.
  3. So yesterday I woke up and got in three perfectly normal drags off my vape before noticing that the display wasn’t working properly; as I took my drags the wattage value wasn’t changing, and furthermore when I went to lock the device and access the menu, it lagged significantly, and different sections of the display would change a second or two before other sections. Shortly after, the mod would only fire for a few seconds before cutting off, glitch text would run through the display when I tried messing with it, eventually it stopped firing altogether, and finally while I had it on a charger yesterday evening it displayed a Warranty Service message and hasn’t done anything since. Does anyone have any suggestions for steps I might take to rule out possible issues I could take care of myself? Also, is there any way to perform a hard reset on a DNA 250?
  4. So it’s been some time since I’ve used temperature control, and I’ve never used it with 316SS, but for some reason the Temperature Protect warning comes on nearly immediately despite my power being set to twenry watts, I’m getting hardly any vapor until over five hundred degrees - and even then it’s a paltry amount - when I turn on Monitoring Mode, the temperature seems to start straight at five hundred degrees. It’s almost as if the base temperature of my coil is set at five hundred degrees Fahrenheit, though I don’t know if that’s possible. Anyone have any clue as to what’s going on?
