I've had my paranormal for a little over 2 months, and last week I had it sitting on my desk and it started auto-firing.  I popped open the battery try to make it stop, closed it again, and the problem went away, until the next day.
	It was fine for another few days, but I set the max puff time down to 6s and lock time to 5 minutes just in case.
	It just happened again, so I figured I'd hook it up to eScribe and restore defaults.  It connected fine, downloaded the settings, but I got an error trying to restore defaults: https://i.gyazo.com/b9be250347ee3aa1d8957d4c28f606e5.png
	There also seems to be some issues with the buttons.  My normal unlock sequence is FFF, however when this problem happens, F does nothing, and up/down/enter 3 times will bypass the lock screen and seem to be acting as fire buttons.
	I tried contacting Lost Vape but they haven't responded, and VaporDNA says I'm past the 30 day return rate.  Is there anything else I can try?
	I did have an RDA on there that was leaking out of the 510 screw, so I opened up the Paranormal and cleaned out the bit of juice with a q-tip and rubbing alcohol, but there was not that much, and no signs of it trickling down to where the board is.
	Unsure what to do next, as it's pretty much unusable at this point.  Even taking the batteries out for 5 minutes, then re-inserting them and the problem persists.
