Hi,
	I have a Therion DNA 167. It has been an amazing device so far. Had only one bug with this device so far which is EScribe doesn't detect it is a 2 cell parallel device. When you upload the new config it bricks the device. Yes I already made a ticket for that but this wasn't a bug.  Strange,  right? They assume you know EVERYTHING about your device. And that after you install EScribe you also magically know why and how to enable manufacturer UI and set battery back from 1 cell to 2 So yeah whatever that aside.
	I just recharged my Therion because the battery was at a critical low level I think maybe 4% or something (Yes i configured the lowest discharge rate of the batteries in EScribe). everything was fine, I just plugged it back in my Asus Nexus charger which is a 5v 2 amp charger for fast charge. After the charging for some time I came back and wanted to unplug it and I see the message on the screen; WARRANTY SERVICE.
	So first thing I did, unplugged the device, took out the cells and checked everything.
	So I took my fluke multimeter and measured the cells; 4.52 volt each, according to the datasheet this is the MAX full charge voltage.
	I am using two original eFest 3000mAh 35A IMR 18650 cells, which are rewraped LG MH1 10A cells. Which is indeed after my testing right.
	Time,Power,Meter,"USB Current","Battery Cell 1","Battery Cell 2"
				64.0069999999987,,0,0.003,4.52,4.52 (.... ramping up)
					81.1829999999995,20.02,-0.002,0.004,4.44,4.44 (.... taking the full current after ramp up)
					The charger I am using is a AD83501 (that came with my Asus Nexus 7 from 2012 already sold the tab, I lost the charger that I later on found again and used for my e-cig) .
					The adapter has the following certifications:
					TÜV SÜD GS
					FCC, UL, CE and RoHS Certification
					Built by www.pctinternational.com
					Tldr; It's not a Ebay knockoff garbisch peace of %*&? ! I know what poor adapters can do this is why I avoid them.
					So what is this message.. I have never seen it before until today.. I am worried. Is my device dying? I've only ran 350 ml through her so far, I am not even a chain smoker got this Therion maybe a year now..
