HarryHunt
HarryHunt's Achievements
  1. Thanks a bunch for the advice👋
  2. At what temp does the cotton usually start to char?
  3. Is this common practice? I’ve never heard of this before but it sounds smart. But it doesn’t seem like temp control vaping was designed to work like this other than the dry hit protection. I’ll give it ago anyway. At what temp does the cotton usually start to char?
  4. What mode are you in for this
  5. Yeah well that makes sense I guess. How do I check if the internal resistance of my mod is calibrated properly?
  6. Jonski, how do u mean properly calibrated? Do the dna chips not come properly calibrated?
  7. Yes it’s the 75c. I’m just wondering if by turning up the watts to max that the board will be working inefficiently by trying to control the set temp with such a high input wattage. I just find it strange that there are no guidelines for this anywhere. My common sense tells me to set the watts around what I would normally vape at in wattage mode.
  8. Hi, I’m new to temp control. I have a 316L spaced single coil that ohms out to 0.37 ohms. I like to vape this at around 35 Watts. My question is, how do I convert this to temperature and how do I know what to set the power at to get a similar vape? If I have the wrong forum, could you point me in the right direction. Thanks in advance.
