rONin
Everything posted by rONin
  1. Got it sir anyway, I heard DJLSB say "stable vape" and "same exact vape experience" so I thought that was the way to go. Again sir, thanks for your time and patience and maybe try that triple core again sometime but not soon.
  2. Could you elaborate on this sir? It's still the same brand only with 2 cores instead of 3. I've read from somewhere or heard from here @ 23:44 to lock the resistance so I assumed it is the proper way. Anyway, I'll leave it unlocked from now on. Again, thank you sir for your help.
  3. I'm sorry Sir about not telling you about the change in power, I assumed that I had to change the wattage from using a round wire to a fused clapton. I didn't make the wire, I bought it from here. I thank you for your patience. I'm a beginner vaper of roughly 2 months and I just want to get the best experience from vaping. I tried another wire with 2 cores, at first the vape was hot yet the temperature doesn't reach the set temperature. I removed the wick and I pulsed it red to check. Then rewicked it. I've been doing round wires without pulsing them without problems. I should maybe dry fire the fused claptons? But they said not to dry fire SS316L. I have this screenshot after I had rested the coil for a few minutes and locked the resistance, I also changed the Temperature and the wattage.
  4. Yes sir but I lost a lot of flavor from using the fused clapton.
  5. Here sir I used a coil master ss316L 26 awg round wire on the RDA.
  6. The 0.5 ohm coil is on a single spaced coil RTA sir and the 0.18 is a single coil spaced fused clapton a RDA. Should I replace the coil on the RDA? and yes sir It is room temperature.
  7. I use spaced coils sir, I lowered the power and used the default profile and this is what I have. Is this working right? I also don't dry burn SS316L as I have heard that it could be dangerous.
  8. yes sir I just tried a .5 ohm ss316l 26awg tank and it works fine.
  9. I built a new coil using the same wire with 1 less wrap... Still saying "OFF"
  10. Hello guys, I need some help with my HCigar VT 167, I have just notice while vaping the temperature message reads just "OFF", the resistance stays at 0.24 ohms I'm using SS316L Fused claptons 26*3+38 4 wraps 2.5mm diameter inner core. I used the SS316L material profile from here. Thank you.
