Edwin1967
Edwin1967's Achievements
  1. Thanks for sharing, but this is the Vt75D, so with 2 18650 batteries. I will try to create the device monitor screenshot in the weekend, hopefully someone will have an idea, for I love the size format of this mod.
  2. They could't determine what caused the failure, and didn't answer my final questions, so I left it with that. Now I tried the mod again after a long time, but still the same problem.
  3. Still not resolved, any more ideas?
  4. Thank you for the link, I posted the problem there and I hope they can help me.
  5. The openings in the curve show when it misfires and resets.
  6. This is what it looks like in Escribe:
  7. Yes when you are just vaping, you notice it stopped firing, then you can see the screen is black, when you activate it again (5 clicks) it shows the startup screen and it works again, for a few puffs before it happens again.
  8. Thanks for the reply, but the contacts are cleaned with alcohol and the spring seems to work ok? Also no arcing marks, just nice and shiny.
  9. I have a VT75D for some time now, but from the start it has a problem. The 75C board resets itself spontaneously on an irregular basis. When vaping it performs okay but sometimes after two vapes it resets and sometimes after 20 vapes. I tried escribe several times to adjust settings, but doesn't help, I cleaned it which doesn't help also. Eventually i opened up the modand made sure battery contacts are all good, still no solution, does anybody have an idea what to do?
