cmpvaz
Everything posted by cmpvaz
  1. Thank you all, I have already discovered the problem ... too much cotton !!
  2. How can i do that? If all are working fine, can i have some help with the build? like materials, gauge, ohm....?
  3. I made a print screen with single coil NI200 @ 0,11 ohms. I don't have any experience in escribe. You see anything wrong?
  4. It's all tight and it happens with two different atomizers. There is always a little amount of steam and cold. Probably some problem with the build? Any build you recommend for TC, type of wire, ohm...?
  5. I know... but the question is if is normal that message come sow quick... like two short puffs and is already in temperature protected? Anyone knows the reason?
  6. Hi, I bought a Therion 166 a few days ago and I have a doubt / problem, in temperature control after two vapes for about 2 seconds each the mod always enters "temperature protected". This happens with both a bild of SS316L 0.45 ohm and with NI200 at 0.11 ohm, the steam is always cold / warm. The temperature is in the 450F and the watts in SS316 are set to 35 and in NI200 to 70w. Any clues to solve the problem?
