Phoenix Box Mods
Phoenix Box Mods last won the day on January 22 2021
Phoenix Box Mods had the most liked content!
1 Follower
  • Full Name
    Scott F. Eisner
    United States
    ALL DNA
Phoenix Box Mods's Achievements
  1. Hello owners of Phoenix - I have an ipdated 250c theme ive been runnning for a year now you may have to adjust battery for your mod but this includes nice features - also modify the name to refeclt the model clock , moving battery indacator and a full showing of voltage for each cell www.phoenicboxmods.com Hydra 2025 orange.ecig cerberus regular 2025.ecig Siren 2025 orange.ecig
  2. dna250 can and may use up to 28 amps in 250 and 32 on 250c so this M12 isnt a good battery for the dna board
  3. usb will not try to charge an very unbalanced battery - this battery is in bad shape and maybe you can balance and recover with a very nice outside charger
  4. shave the buttons - do not shim the holder - the holder should be flat when epoxy is added to make sure it holds tight when usb is pulled in and out - sand the buttons simple fix
  5. So today another one - ive had a run of bad usb ports in the past month total now is 4 will not connect to escribe issues - no charge issue - the boards dont seems to be from any special build time from jan - nov to be out 4 boards for warranty in the past month is not normal. anyone else having issues ?? i set lipos at 2.0 amp charge limit in device monitor idk whats going on
  6. I normally do share them since ive been building and selling dna mods since 2015 but the post is for themes for a few models Phoenix Box Mods with our logos and such. figured this would be the best place to post them but i will also share them not sure why anyone would want a Phoenix Box Mods theme on a non Phoenix mod.
  7. NEW for 2022 @ Phoenix Box Mods We have updated our theme colors for DNA250C for anyone wanting the new theme with new changes you can download here We have added : Clock into the home screen changed battery display colors and added a charge indicator (lighting bolt) meter is white green when full Color scheme also has changed if you have a model not listed please email me phoenixboxmods@gmail.com www.phoenixboxmods.com download the correct version of escribe (international version) here: https://www.evolvapor.com/escribe Hydra Theme 2022.ecigtheme Kraken theme 2022.ecigtheme Chinera theme 2022.ecigtheme Eternal theme 2022.ecigtheme
  8. lipos require 6-10 full cycles for the battery to break in - normal short life get longer after a few more charge cycles
  9. Here are the new 2020 updates for Hydra 4s , Siren 4s , Kraken and Cerberus will be be adding more as we move along New cerberus 7 2020.ecigtheme new hydra 7 2020.ecigtheme new siren 7 2020.ecigtheme New Kraken 7 2020.ecigtheme
  10. lipo batteries have a break in period - normally 6-10 full charges before the battery will perform as it should also the battery is not at 50% its reads 50% of use. All cells stop at 0% but the battery is set to cut off at 3.15 per cell so the dna chip can recharge Turnigy High Capacity 5200mAh 4S 12C 5200mah @ 12c = 62.4 amps dna 250 max amp use amps is 32 amps this battery has plenty of room
  11. anyone have the CSV for 21700 4ot yet
