gkenney
Everything posted by gkenney
  1. Really a good looking final product!!
  2. Update: I've opened a ticket with Evolv and they've requested the Theme. I'll update as things progress.
  3. Modcrate - Silo DNA75C
  4. Background: I know how to lock the ohms through eScribe but I would like the option of locking the ohms when away from the computer. Using the Theme designer I created a toggle in the Atomizer screen. After creating the toggle, I used the Coil Ohm Lock option and uploaded the theme to my device. The toggle shows up in the device atomizer screen. It also toggles correctly if I change the ohm lock in eScribe and upload to the device, so it is reading the changes made from eScribe to the device. What isn't happening is an indication the Ohm Lock has changed when I download the device settings into eScribe. If I go to the Atomizer screen on the device and toggle the Ohm Lock then download the device settings, Escribe is continuing to show the ohm lock setting since the last upload to the device. eScribe captures other changes I make in the atomizer screen. For instance, if I change the resistance value through the device using the atomizer screen, then download the settings to eScribe, the change in resistance is captured. This tells me eScribe can accurately capture updates to an Atomizer Screen field made through the device. Question: Can I toggle the Ohm Lock in the field by creating a theme having a toggle using the "Coil Ohm Lock" option? If so, is there anything I should be doing to that field regarding conditions, etc that would make this a reality for me. Any help is appreciated.
