DrippYLippY
Everything posted by DrippYLippY
  1. Thats got to be something with your laptop because the USB 3.0 is capable of 1amp Max Current as per the specs and mine is charging at 1amp right this second or to be precise its @ .97 amps
  2. Boss your right. The Blue USB 2.0 Ports Charge at 1amp while the Yellow USB 1.0 Ports only charge at .5 amp and the Black USB on my Video Card is able to Charge at 2.4 Amps which is great if I ever get a Vapor Shark 2amp Zip Charging DNA 200... Iam not scared of LiPo's at all, I love these things, just which the Hana came with a bigger pack... 1800mah 3 Cells would last me a full 24 Hours in Temp Control at 80 to 100 Watts
  3. Yeah the Hana V200 is only 10.5 Watt/Hours its a 950mah 3 Cell 30c Lipo, so its alot smaller then your 2000mah LiPo, If your getting over 2 days then i should be getting atleast a work day which would be 8 Hours but iam not. I do know that Temp Control drains the cells alot faster then Kanthal mode, 80 watts in temp control is prolly like 150 in Kanthal, but i still feel like i should be getting better life out of this LiPo. I did change it to max Puffs which should help and its now charging at 1amp which should also help. In the very near future iam just going to get a spare LiPo and a LiPo charger so i can just swap like what you do with 18650's but i think once i get this LiPo dialed in correctly i should be able to get 8-9 Hours out of 10.5 Watt/Hours
  4. Yup beard you were right... The brightness of the charge screen was set to 0% in Escribe. Now its charging at 1amp with a 2.4amp wall charger but its still only charging at .5 amps from the computer. Do you know of a way to change the USB Current on the Computer to 1amp?
  5. i dont understand how to see the charge screen? I have it setup but everytime i plug into usb regardless if its PC or Wall Unit it still has the same screen.... Do you have to enable the charge screen somehow with the buttons???? I the only thing i get is the battery meter showing it charge
  6. Hopefully someone can help me figure out what iam doing wrong, But my LiPo in the Hana V200 Production Version is taking forever to charge and drain's super fast. I pluged it in to eScribe and its only Charging the LiPo Pack at .5 Amps and i thought that this version is suppose to have 1 Amp Charging thats advertised on its website. I cant find anywhere on my computer to change the charging current on the USB. Does anyone know how to do this? Also does anyone know what i could buy that would allow me to charge faster thru the USB? My last question is there anything in EScribe that will allow you to get better battery life without having to run in Stealth Mode? Iam only running at 80 Watts and 420F and i only get about 3 1/2 to 4 hours on a full charge.
