reeder359
reeder359's Achievements
  1. Okay so I'm sitting here and my mod is plugged into the computer and it won't read that it's plugged in. But my battery percent is at 0 and it's still firing the tank I have on it. I don't know what's wrong with it
  2. Is there anyway to reset it not plugged in to the computer?
  3. It's the same cord I've been using since I built the box. It just stopped charging today and won't charge at all
  4. I've used 3 different USB cords and the screen or computer won't read that it's charging or even plugged in. I'm really disappointed. I have had nothing but problems with my dna 200. Please help
  5. Could anyone give me a link to a good 1300 to 1600 mah battery with all the needed ratings for the 200 chip? And a small sized one?
  6. What's the best 1300 mah battery put there that's a small size.
  7. True. Do you know where I could find a smaller one with the same ratings as that battery?
  8. And will it fit in a 1590b box? And does it have the same connections
  9. My bad forgot to paste the link. http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=8932
  10. Will this lipo battery work with the 200? Is it compatible and safe for all the wattage the chip has? Thanks
  11. Awesome thank you
  12. Are they these holes https://twitter.com/suzuki359/status/632573105462972416?s=09 and what pattern does it go fire , up, then down?
  13. Do you have to de solder the existing buttons to wire in new buttons?
  14. What I meant by more durable is I don't want the on board buttons to go out on me and plus I would want more of a clicky button to press when I vape it. I want to feel that I'm actually hitting the fire button or plus and minus buttons
  15. I'm wondering if you could use different buttons for the fire and plus and minus buttons. Could you wire everything to the board with different buttons instead of using the on board buttons? I want this mod to be durable and long lasting. This is my first box mod build and would be greatly appreciated if anyone could help me out. Thanks
