gerax07
gerax07's Achievements
  1. I fit 2200mAh batteries in the hammond B boxs. Finished https://instagram.com/p/6Yp84WAWEc Basically the internals. https://instagram.com/p/545cYQgWPy[/QUOTE] You're a facking genius, could you post pics of the internals of a finished build? I have the exact same components and I was wondering how in the hell did you do it.
  2. Hey y'all, I found this 100 ohm resistor from an electronics company that is close to me. It is almost identical to the resistor Brandon posted, but it has a 50V voltage rating. It's this. Y'all think it's OK for my build?
  3. Thank you, we appreciate it.
  4. If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'. Resistor link Above the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board. That will give you what you want.[/QUOTE] Could you show us in a schematic how to do so? We can't figure out where we would need to solder the resistor. And by doing so, do we not need any of the other resistors/transistor?
  5. Well, we want to wire in an LED fire button, and have it only light up when we fire the mod. Wouldn't wiring the LED straight to the board make it always be lit up?
  6. A friend and I got together and decided our next step from mech was to build our own boxes, and so we decided to buy the dna200 and make a great box out of it, one for each of us, and have an amazing time while doing so. I just wanted to check with y'all, since y'all seem to have a lot of experience when it comes to this particular subject. This is my part list, do y'all think everything is good? Please feel free to tell me if any parts will conflict or if we're doing something wrong. Battery: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8932 Enclosure: http://www.ebay.com/itm/Alpinetech-1590B-MBK-CNC-Milled-Aluminum-Enclosure-Box-Hidden-Magnet-BLACK-/221838484690?hash=item33a69aa4d2 Fire switch: http://www.ebay.com/itm/MB16F-W-ATI-16mm-Momentary-White-LED-2-8V-4-3V-PushButton-Switch-Flat-Top-Black-/321633536740?pt=LH_DefaultDomain_0&hash=item4ae2da4ae4 Up/Down switch: http://www.mouser.com/ProductDetail/CK-Components/KSJ0M43180SHLFT/?qs=sGAEpiMZZMtn8lxF5bBjIcLvXe4ql53t 510 Connector/Cap: http://www.fatdaddyvapes.com/shop.html (What size do y'all recommend?) Magnets: http://www.ebay.com/itm/N52-Black-Magnets-for-Hammond-Box-Mod-4-1-4-x-1-8-Disc-4-1-8-x-1-4-Cylindr-/321780355551?pt=LH_DefaultDomain_0&hash=item4aeb9a91df Resistors: 680: http://www.mouser.com/ProductDetail/Vishay-Dale/CMF07680R00GKR6/?qs=sGAEpiMZZMsPqMdJzcrNwmyXKdlxrkSRaUdyGRk3zIU%3d 4k7:http://www.mouser.com/ProductDetail/Vishay-Dale/CMF604K7000FKEK/?qs=sGAEpiMZZMsPqMdJzcrNwmyXKdlxrkSR2Dvt3Ie3RX8%3d 10k:http://www.mouser.com/ProductDetail/Vishay-Dale/CMF6010K000FKEK/?qs=sGAEpiMZZMsPqMdJzcrNwohr4TA0SfZbzszyc8DC8m4%3d 20k:http://www.mouser.com/ProductDetail/Vishay-Dale/CMF6020K000FKEK/?qs=sGAEpiMZZMsPqMdJzcrNwohr4TA0SfZbQvpr%252bFn8STI%3d PN2222A Transistor: http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/PN2222ABU/?qs=sGAEpiMZZMshyDBzk1%2fWi8oN7VHZ91Oksd99mJbzy1A%3d Male XT60 Connector: http://www.hobbyking.com/hobbyking/store/__43759__Male_XT60_connectors_5pcs_bag_GENUINE_USA_warehouse_.html Wire: http://www.hobbyking.com/hobbyking/store/__466__377__Hardware_Accessories-Silicon_Wire_Mesh_Guard.html I really appreciate it, and any input or tips y'all have will be very welcomed. Thanks in advance!
