Zenataos
  • Full Name
    Steven Ryan Pearce
    Canada
    DNA200
Zenataos's Achievements
  1. Should be nothing wrong with the charger / cable, as long as you can get it to charge at 2amps your cables etc are fine. I think maybe the 4.21 is part of the battery settings @ 10.22 watt hours although I never checked the voltage at that setting for mine. The DNA chip and built in balance charger shouldn't overcharge the batteries.
  2. going to give it a few cycles at the 9.99 watt hour setting (the graph still shows 10.224 watt hour for some reason) as it seems to have stopped the short charging meter (all times charged 94 / 88 /76 etc were all what read on the device after charging overnight at the 10.22 wa setting) so far 2 cycles at 9.99 watt hours and charged to 100% both times
  3. I'm not sure I'd want the cells showing 4.21 volts... AFAIK that's slightly overcharged and will shorten the battery life. 4.2 volts / cell is full capacity. I don't believe getting to 4.21 is going to hurt anything that bad but still... don't like it personally.
  4. It still charges to 4.20 volts, the meter just clicks from 99% to 100% at 4.17 volts and it continues to charge at 2 amps until 4.20 volts then the amps slow down / balance / stop.
  5. I manually changed the 10.22 to 9.99 and now it will charge to 100% no problems (when I load escribe it hits 100% at 4.17 volts and it WILL continue charging on it's own at full rate to 4.2 volts but just stays at 100%... other than that haven't noticed anything funny.
  6. I haven't messed with any of the settings. Still set to vs defaults.
  7. VS DNA 200 My gauges show battery %... first time I set it (in eScribe) as 100% (on a full charge), fast forward a day or two and a few charge cycles, first cycle will go to like 94% on the meter but show 4.2volts in escribe and balance cycle has completed, 2nd cycle will show like 88% and 4.2volts, 3rd cycle 75% and 4.2 volts... this can be fixed by loading escribe and selecting a different screen setting (don't show the %) then redo the % ... and it shows as 100% at 4.2 volts... Haven't noticed any decrease in battery life between the charges... is this just an escribe bug? Or is this just me?? Zen
  8. I second this! I have a Ninja Turtle and my name come up on my two right now, but I love geeking out of this kind of stuff and more would be awesome. I know it has little to no affect on end user vape experience but it's always cool to customize your things!
