Have received a dual 18650 dna200 mod
Want to check I have the correct calculations
Using two sony vtc5 batteries
2600mah 3.7v
My calculation is 5200mah à 3.7v/1000 = 19.24
Think I'm right but wouldn't mind confirmation
Thanks in advance
Glen
Quick update, been charging and the three cells charge at the same rate, when I take few puffs the three cells drop as expected, cannot understand why the battery discharged when not getting used unless somehow the board thinks its in use, have checked all connections on the battery pack and the all appear fine, very strange
I have a vapor shark, battery is set correctly on escribe,
Was just using it with 62% charge left on battery, put it down, returned to it a few minutes later and the battery had dropped to 38% charge remaining
Cannot see what is causing this, the fire button does not appear to be sticking, anybody out there got any ideas
Cheers Glen
Hello everybody,
No matter what build I use I get the temperature protected message on my mod
I have a 0.2ohm coil
Temperature set at 430f
Wattage set at 20w
It vapes perfectly but I am concerned about the protection kicking in, as it doesn't do this on any of my dna40 devices.
Any help would be greatly appreciated
Thanks Glen
