This has happened because you have got too much heat on the board, effectively melting the pad off of the board, and now that the pad is completely off the board you have broken the PCB trace as well.  Solder with less heat dude, tin the pad, tin the wire, and preheat the wire before making your solder connection, you want the iron to be in contact with the board for as little time as possible, so when your tinned wire has molten solder, just place it on the pad and remove the heat. Don't put the wire on the pad and heat the whole thing up till it joins.  PCBs are very fragile and sensitive to heat.
