mkla213
Everything posted by mkla213
  1. Hello Everyone, I'm having an issue with wattage not reaching its set input. If anyone could give me some advice as I never had a problem with this in the DNA 200 it would be much appreciated. Specs: Kennedy Box Mod (166w) w/ New 2 x 18650 (LG) batteries married and fully charged. 0.1 ohm build (24g parallel clapton coils w/ ni80 36g). It's set on wattage/power at 120 watts. but when I fire it only reaches to about 77 watts. when I throw this same atty on my dna 200 at 120 watts it reaches the 120 watts no problem and creates desired hit. any ideas? will gladly provide more info related to the resolution of this problem.
  2. I could see fake mxjo's being re-wraps of the Hg2's. I doubt you would think the authentic are re-warps after making the comparison yourself which I have tried and yes I understand the results are subjective. To each their own. I was thinking of using the battery analyzer since is obviously the best option. But re-building and draining fully charged batteries for that test wasn't going to happen for me. My whole purpose for running into two months testing was to see if I could get the "weak battery" indicator as close to 0% as possible. Just curious. Do you use percentage in one of your fields? At wat percent does your "weak battery" indicator start to appear?
  3. Took my about 2 months to get this thing to where I like it! Using 3 Authentic MXJO's 3000 mah 3.7V batteries. Beware of fakes. Also, I changed my field one to show Battery Percentage which helped me create and test this chart. I vape a 0.10 ohm build at 120w. I get the "weak battery" indicator message about 3 hits after my percentage hits 0%. (which is the BEST configuration I have created so far) I used to get the "weak battery" hours after it hit 0% which really bothered me. During testing other configurations I would get "weak battery" at 23% which still really bothered me. So far this is my Ultimate Configuration so that my battery meter / percentage is discharging accurately for what I see on my screen. There's so much crap to factor in but that will be another discussion. MOD > Manufacturing Settings > Battery TYPE: Lithium Polymer Capacity: 33.3 Wh 3-cell Cell Soft Cutoff: 3.09 CHART Battery Charge (%)Cell Voltage (V)03.3500061040.9997192623.3999938961.9994385243.4499969483.9988770483.55.9983158113.5500030528.5019350053.5564575211.797839163.56704711917.701080323.57791137723.601440433.58663940429.501800543.60000610435.399280553.64999389641.299640663.69999694847.200000763.7553.100360873.80000305259.000720983.85000610464.901077273.89999389670.801445013.94999694876.6989212482.599281314.05000305288.499641424.10000610494.400001534.149993896100.00073244.2 For Battery Percentage Round to the nearest tenth or whole (random manual placements) For Cell Voltage Round to the nearest thousandth (I jump by .5 per row) (ex. 3.35 to 3.4 to 3.45 and so on)
