addappt
  • Full Name
    Stefan Trotta
addappt's Achievements
  1. From my experience the main issue with dual coils in TC is twice as many possibilities for a bad connection. Usually if I have any issue it is to do with a post connection being bad or uneven. Retentioning of post screws usually fixes he problem.
  2. addappt
    Dead Unit
    Bap is correct, your best bet will be to contact the mod manufacturer for service. Warranty Service is triggered by certain components on the board being out of spec, electrically. The board can continue to function in this state but will fail completely eventually. [/QUOTE] Cigreen response... hi bro Yeah. Maybe battery died. Evolv chip has a bug which cause battery power down speed fast. You need to update it with newest firmware in their website. But if the battery is dead it will be useless. Pls kindly send it to your distributor and we will change new battery and new firmware withit. Thanks for your support all the time. Best regards Jason Liu
  3. Mine died completely as well. Black screen. Intermittent recognition of device in escribe. Funny response from Cigreen 'hi bro Yeah. Maybe battery died. Evolv chip has a bug which cause battery power down speed fast. You need to update it with newest firmware in their website. But if the battery is dead it will be useless. Pls kindly send it to your distributor and we will change new battery and new firmware withit. Thanks for your support all the time. Best regards Jason Liu'
  4. addappt
    Dead Unit
    Ok thanks. I've started the RMA with the shop I bought it from.
  5. addappt
    Dead Unit
    Sometimes it will recognise and sometimes it won't. It started out with a screen glitch that would cause a soft reset and then with time it came up with the warranty error. The error went away after resuming from standby but after a few hits it died completely.
  6. addappt
    Dead Unit
    Anyone?
  7. addappt
    Dead Unit
    Spoke to soon. Completely dead now.
  8. What about it if it reads 83622 and keeps going up in the thousands?
  9. addappt
    Dead Unit
    Let it sit for awhile and it started working again. Now though in normal mode it will freak out and fire above set watts and the screen will glitch and then it does a restart.
  10. Built in. It's been buggy lately. Warranty service error on screen and doing restarts randomly.
  11. addappt
    Dead Unit
    My SVIP just died. See pic. So what now?
  12. Thanks mate. Can you explain the reason behind changing the voltage setting?
  13. Ive had success running dual 24g 6 wrap builds on my drippers as well as using the Ti profile to run my Delta 2 LVC Ti coils. The flavour on the pre-made delta coils is awesome and it regulates them perfectly.
  14. I have had mine a few days now and it seems to be running fine. Had to do a recovery charge when new to get the cells above 3v and needed to reset the battery capacity in escribe as it was set to 9wh but its taking a full 16.65wh of charge from empty and seems to be running perfectly. Never gets hot or anything for me.
  15. When plugging in my unit to escribe i noticed it was set to 9 Wh 3 Cell under the capacity setting. The SVIP is supposed to be 1500mah which works out using the watt hour calculator to 16.65Wh so i set it to that. Is that correct? Will this actually change anything with the unit? I noticed after doing this the charge indicator actually went up on the device (its saying it is more charged then before the change)?
