            MuTong
                Posts28
                Last visitedNever
Everything posted by MuTong
	When charging, the chip is hot.Can be normal use.9.2v,Chip heating is caused by low voltage? Battery selection, 25C / 20c / 30C / 35C?What are the requirements for battery selection?
	  Purchase less than screen???MuTong replied to MuTong's topic in Connectors, Components, and Accessories It seems like I'm going to buy a second-hand DNA40 with big screen.
	  Purchase less than screen???MuTong replied to MuTong's topic in Connectors, Components, and Accessories Dna200's screen is damaged, and in China can not buy, only to find the 14pin interface. Is there any way to solve it?DNA40's screen can be common?
	Thanks Mad Scientist, I will try to re weld all the connecting lines.
	Thanks UKDTweak and Mad Scientist, I don't have a clear description of my question. Even if I do not use USB charging function(external charger), all of the connecting line is necessary?
	I want to use two 18650 batteries instead of battery in vtbox200. Space(72*35*22mm) should be able to lay down 18650?2 battery box. 1.Can I just connect the output line to the dna200 chip and USB only for updating the firmware? 2.Annex can be used for all 18650 * 2 ? 3.I have to do is to update the discharge curve, choose 2-cell?
	I want to use two 18650 batteries instead of battery in vtbox200.I don't know whether it is feasible or not? Space(72*35*22mm) should be able to lay down 18650?2 battery box.Can I just connect the output line to the dna200 chip and USB only for updating the firmware.
	After two days I will receive the vtbox200, I will be here to do a comparison.
	  After the revision of the vtbox200MuTong replied to MuTong's topic in EScribe, Software and Firmware Sorry for the wrong place.
	  After the revision of the vtbox200MuTong replied to MuTong's topic in EScribe, Software and Firmware After two days I will receive the vtbox200, I will be here to do a comparison.
	I am a Chinese, English is not good, I hope to express clearly. Must pay attention to the default USB connection virtual machine, Prevents usb disconnection when the firmware updates.
	My computer is also Mac, you can use the virtual machine. But to pay attention to setting the default link USB virtual machine.
	Dna200 chip, the fuse is burning, can I fix it myself.I judge the box is for this reason to stop working.
	I found a new yihi SX Mini ml class? chip 350jv2. in response to dna200.
	The battery capacity is not important. Don't be broken. I'm crazy. connecting the computer I must first remove the battery
	Hi, 1500mah battery I also found, I think he can be used as other parameters are the same size.I am very surprised that I am also strange to the battery brand, and no sales of this battery 1800mah.
	robby How do you charge it, use USB to link the computer? My two boxes are damaged when they are connected to the computer.
	Yes, the domestic customer has been reflected, they promptly corrected, the two identified, linked to flip, 510 replacement
	robby If they replace the updated product to me, I will evaluate the release here
	In China after the update of the product has not shipped
	This batch of 00200 before the product is indeed a lot of problems, I hope the manufacturers to replace it.
	I consulted the manufacturers, they in the second batch of products has been improved, 510 joints were replaced, battery T shape link reversed.
	Hi Mad Scientist, I tried, the screen is still black, PC still can not find the chip.When connecting usb chip will heat.I also tried to remove or connect the battery when there is a USB connection.I found the box problems are in keeping with a computer connection. I also listen to some Chinese friends have a similar situation. They now use 5v1a phone charger, avoid prolonged connected to the computer. sorry,My English is general.I hope my description is clear.
