CanadianCough
Everything posted by CanadianCough
  1. Hi, this is a super new problem ive just come across. It is more than likley an issue with my computer and not escribe or anything. So i am hoping someone here is a little more tech savvy than me. ive created CSV files with wire wizard before, saved them and opened them in escribe no problem. Today however i went to make a file for SS. I saved the file and the file shows up in my documents where i saved it, but when i go to load the file in escribe the CSV is does not show up in the location. I have saved it to 3 different locations (downloads, documents, and desktop to be super sure its saving). I will then open my computer tab to make sure its still in the file where i have saved it. Nothing has helped and no matter where i save it the file "doesnt exist" or even show up in the folder. Is This something to do with my partition coming to its final days or is this some weird bug? i have installed the last 3 versions of escribe as well with no luck. im using my SS in power mode for now but i have lots of ni80 and kanthal if i want to use power :/
  2. you used 30g instead of 32 by accident. i recreated the "correct" coil and the resistance in the calc was off by 0.04ish which is a lot i feel. i loaded the tfr curve and my temp is getting closer to desired temp (about 20 degrees higher or so) on graph but still feels hot which is confusing. live ohms still look stable.. i really appreciate all the help too by the way, thanks a lot.
  3. i know about uploading csv files for other alloys. i triple checked the factory curve for ni200 with the wire wizard file and its perfect. My Coil is 26g fused clapton (para 26 claptoned with 32 all ni200) 7 wrap no spacing on 2.5mm stud. My coils are going to stay ni200 for a while, i havnet read many good things about other alloys but again i havent done much reading lol. plus ni200 is readily available to me Im not being stupid by just waiting for replys to this thread, i am constantly looking around for answers and different solutions, everything is this thread ive already tried excluding asking if its my coils which is a possibility but ive built 3 different coils all to no avail with the same outcomes on readings and graph output. with this much nickle sitting in a coil is that what is affecting it? doesnt really make sense since ive had a regular spaced coil clapton and fused clapton all read the same (wrong)
  4. Lol yes its ni200, I'm wondering if the curve may be wrong. I'm going to download a csv for nickle
  5. You mean checking the tcr curve of the nickle200 profile in the tab for type of wire? Ive set my mod resistance and now the temp portion is working and settling out within 5 degrees of what is set. Live ohms are barely more than a flat line still and the first hit is always weak like it forgets the settings while it's coming out of sleep. Also now having z problem with extended idle times and COMPLETLY ignore the fact there is a Tc coil on. Doesn't even ask if new coil just gives in Watt mode. Fix one thing create another.
  6. i dont know if you have figured it out or not but this is a bug that can be worked around. My friend and i both have the same issue with our lava boxes with correct settings. Its just an annoying bug that will be fixed. We dont know what causes it. SO lets get to the steps.... 1. put on your atty with desired build click yes for new coil 2. set watts to desired setting 3. fire mod for quick sec. does it display temp readout? obviously not. this is where fixing it comes in 4. lock device and turn off temp by scrolling all the way up, not down 5. unlock device 6. fire device 7. re lock device and set temp do desired setting 8. unlock and fire, the device should be reading your temps correctly now if this doesnt work, instead of setting watts to desired setting in step 2 set them to 1w and fire the continuing the process and set watts to desired setting before firing in step 8. I have been looking literally everywhere for someone else who knows about this bug instead of just saying MOD ISSUE WARRANTY SEND IT BACK. My friend and i have not been able to figure out which setting is causing this so we believe it is just a programming bug. Im scared this bug wont be caught and fixed for a while because its so unknown, which really sucks because its f*cking annoying locking and unlocking and resetting everything multiple times. i dont really know how to explain this bug, everyone looks at me like im crazy when i say its just a bug and dont believe me and have some reason why its not. is there a point in posting to "report a bug"? im new but a lot of it seems largly just community and not the developer of the chip giving a fuck. best of luck and hope your DNA200 is still in your hands and not on the wind powered sail boat back to the supplier.
  7. OK yeah I know the lives ohms should move I thought you were just suggesting that it was indicating a certain known problem. I'm using ni200, set to ni200 in escribe. I can take some before screenshots before I change any settings if your interested to see where I'm sitting currently. The only thing messed with was battery themes and a little screen which seemed to give me a bug where screen isn't on for desired Time according tosettings. I saw that thread before I ran into problems and kind of ignored it and couldn't find it again just assuming I had correct settings (dumb I know). Thanks for the link back to it. Again I can post before screens of the settings if your interested before I change tonight. I'll update with any new information.
  8. Suggesting? Sorry if that's a stupid question
  9. I was actually reading on it before I left for work this morning. In going to try and get a reading with a copper pin and if I can't I'll use there 0.007 I think it is. Will this really help with a 100 degree temp variance in readings and random temp outputs depending on when I set a temp? I didn't think It was THAT crucial, I know it should be set though. I'll give it a shot tonight, thanks.
  10. Hi, i just got a lava box on friday (black friday) and no, no correlation between sales and the box, just coincidence. I am having troubles with a bug that i have not been able to find through the search function which isnt actually why im writing this post. Which has to do with the chip not sensing tc coils and having to go through a series of steps to get it reading and working right. The problem I am posting about now is when i get past that bug which im hoping is fixed in an update sometime soon. When i get past the bug and i am connected to escribe i have my temp set to 440 with a preheat of 100w 1s 9punch, i then open the device monitor. when i take a pull the temp jumps to ~330 and creeps up slowly from there, and the temperature set is still 440. the weird part though is that it feels too hot for 440. If i reset temp to 400 it does the same thing on the graph and settles at ~330 but the temp feels different from when it was set to 440, but depending on if i set and reset the temp it hits hotter or warmer, never constant yet its always settling at 330. so tl;dr no matter the temp im setting, the live temp on escribe settles at ~330 and graph still acts as if its reading and performing right if temp was set to 330. Yet temp does not feel correct to what is actually set and isnt constant (hotter/colder if i switch between temps)
