TempeModder
Everything posted by TempeModder
  1. Voltage seems too consistent to be a connection issue. I have tried the individual cell voltage display and I never see any fluctuation other than typical drain. The discharge curve is all descending, I don't have another battery to try but I may order one just to get to the bottom of this. I am also going to try a 2 point discharge from 4.2-3.09V and see what that looks like. Unfortunately I can't successfully run a battery analyzer test as I am using virtual box on a Mac, I always get a "USB disconnected" message. I am thinking it has something to do with running it on Mac. Thanks for the help, I will probably get over it and just turn off the percentage readout.
  2. Hello, thanks for the response. All settings are correct for the battery and the connections are strong. Can't get voltage to fluctuate at all by moving wires. Maybe just something weird with the battery chemistry? Thanks!
  3. Hello all, When my battery gets to the 30% range it jumps back up to about 55%. I have tried numerous different discharge graphs and modified the default discharge graph and I'm continuing to see the same issue. I can't complain because battery life is more than anticipated just wondering why it does this. I understand that the battery gauge doesn't mean much on this chip but I would still like to get this worked out as I am OCD about this kind of stuff. Home built 3D printed with nano tech turnigy 1500 mah. Thanks in advance!
  4. I got lucky! Works perfect now!
  5. Solved! There was a piece of stray solder shorting out one of the tiny chips just above the balance connector. Working all good now! Thanks all for the help and sorry for wasting your time with my stupidity!!!
  6. Also if it makes a difference I have a VT200 that shows all normal settings and charges properly with the same escribe set up on the mac.
  7. Thank you for the quick response! It only blinks when plugged into escribe, and it's random. Seems that this may have been the cable I was using or something with the computer. I restarted and I am using a different cable and it is no longer blinking. Plugged into the wall adapter no blinking, but still only .1A Changing to 0 did stop charging completely, resetting brought it back to ~0.10 A I do not currently have access to a windows PC I also noticed that my room and board temperature readings don't appear to be accurate. See screenshot.
  8. Hello, I am having an issue with my device only showing 0.10 Amp charge rate on the display. I have attempted to change to 1 Amp in the device monitor but I am not seeing any change. Battery is a turnigy 1500 mAh. I have tried a 1A usb charging block as well as a 2.4, I have also tried 3 different USB cables, several of which are charge cables. Also while plugged into escribe the charging bolt blinks on an off at random. (May be something to do with using a mac with virtual box???) Thank you!
