That battery is not good enough, recommended above 23 amps. I used a Turnigy nano-tech 1000mah 45c (74x35x19) battery soldered positive and negative straight to the board and it fits perfect just to let you know what size can be used .[/QUOTE] i dont push the mod very hard so im not too worried at this point but i do plan on purchasing a better lipo, hence the reason for this thread! just trying to find a great lipo that will fit in this 1590g CNC box
i should add that anything 3mm thicker would require a gasket spacer in the lid for it to work, so staying as close to the stated dimensions as possible would be ideal!
Looking for a good battery to replace the lipo that's currently in my box. It's an Ares 1000mah, 20C (20A) continuous at 77 x 35 x 17mm. It performs well but the battery life leaves something to be desired. I am not a modder, I had this box built for me, but I am capable of replacing the battery. I appreciate your guys' time and input. This forum has taught me many things in the few days since I've been here!
