JLWells1013
About JLWells1013
  • Birthday 11/29/1986
  • Full Name
    Jessica
    South Carolina
    Lost Vape Efusion DNA200
JLWells1013's Achievements
  1. I have all of the settings properly entered per the battery I'm using, at least, according to the manufacturer. 1300mah at 14.43wH and uploaded the manufacturer file with results of the battery analyzer, a few profiles, etc. However, I'm noticing the lightning bolt symbol is still on the device when all cells have reached 4.2 and the charge percentage is at 100. Cell voltage is not exceeding 4.2, like its supposed to. Just curious as to why the charge symbol would still be present.
  2. And about it firing a nickel coil in power mode...should it switch to temp automatically?
  3. By the way, the mod resistance is set at 0.006 and the atomizer is 0.21. Should it be prompting me?
  4. Thank you for your help!
  5. Thanks! And, I've uploaded those settings. I just wanted to make absolutely certain everything was entered in properly. One more question, though. Is there a reason why the device would not be asking me if I'm attaching a new atomizer? I mean, it's asked me maybe three times since I got which was December 23rd, and I've attached and reattached two different atomizers several times and the screen simply doesn't prompt me. I have profiles set up for both atomizers, of course, but with one of them being a nickel coil, I feel like it should ask me. Also, it will fire the nickel coil in power mode if I do not manually switch to temp mode. Is that supposed to happen?
  6. Just got this device and I wanted to make sure I have the settings correct in the software. I have the watt hours adjusted per the user manual, however, does it need to be set for a lithium polymer battery?
  7. Ok, so I just got this device and I'm unsure exactly what battery option to choose in the software. I've watched a few reviewers of the device and all they touch on is how to change the watt hours. All it says in the user manual is that it's a FullyMax 1300mah 3S Lipo battery. Do I select lithium polymer in the software?
