gofastman
Everything posted by gofastman
  1. Oh yeah, duh, far less current draw on each cell (vs. a single cell mech) because of the higher voltage.
  2. I'm using 3 25Rs, nominal capacity is 2500mAh. Capacity in high drain conditions is significantly less. Should I calculate it as 2500, or try to figure out mAh capacity under the conditions they will be used with this device?
  3. Thanks! I assume nominal mAh capacity is used also?
  4. Hi folks, first post here! This isn't necessarily related to the DNA200, but when calculating Watt/hour capacity for the power supply, do you use the batterie's nominal voltage (3.7) or its maximum voltage (4.2)? Thanks!
