Harassment_panda
Everything posted by Harassment_panda
  1. Thank you , you are a savior
  2. can someone post the repair walkthrough on here , i am locked out of FB and they want ID and more info adn im not cool with that and i never wanted the FB in the first place so im not going to join. please this would be very helpful to those who dont have a FB
  3. I would run with the numbers that wismec has given you until you can do your own test. I think mine is a little high ( okay way high for a reuleaux ) and can cause issues for you . I plan on opening up the case and and checking solder points and maybe reflow them. If you go over the actual value of what your mods is , then it could cause havoc on your TC builds and kick you out of TC.
  4. copper rod, use a tap and die kit to thread it for the 510 and go to atomizer analyzer and get reading and times by 0.8~ and it will be a good value to use mod resistance. Also wismec put out a file for the case thermals and i have been using those figures. running lower wattages is fine and i find it more stable of a temp control as long as i hit the temp. also let me rephrase the 200 watt part , you can hit 200 watts as low as 0.08 ohms. you do not have to build down to 0.08 ohms. so looks like the build range for 200 watts is 0.41~ - 0.08 ohms as for the csv file do not use internet explorer to download from steam-engine i use chrome. i have heard the s-e file is good for titanium.
  5. I tired this and OMG flavor. what is a good way to get the springiness out of the 316l? i spent most of my time trying to keep it from springing back into the center posts. and my coils looks like a newbs. this is not my first coil build i have done soo many claptons and fused claptons that i cant even count them anymore. but man twisted ss316l has to be the most springiest thing in the world , even when compared to flubber
  6. The .003 is the reauleaux's internal resistance, this helps the dna 200 chip calculate the actual resistance of the coil and atty. so knowing this if the dna 200 sees a total resistance of .043 it knows the coils and atty is .040 cause it already knows the internal resistance of the reuleaux is 0.003 and because of that can regulate the temperature more accurately. so far i have been able to build down to 0.02 on nickle wire but having such a low resistance coil means i can only use 50 or so watts. to get the full 200 watts out of the dna200 you would have to build at 0.08 ohms. I would still see about doing an actual resistance of the reuleaux as mine came out to 0.058 when i tested it. doing this will help get the most accurate temp control. as for custom images i have just been using paint. and the reason for the image is not "looking so good" is due to the low resolution of the screen. make sure you only do black and white images as it will not do gradients.
  7. I think it has to do with "windows driver package dimensions engineering" as my PC is fine when installing escribe , and UAC for the driver package pops up and i waited a while before clicking yes and the moment I hit yes BSOD and now I can not reinstall package so I can remove it and it does not show in my installed programs anymore. but still crashes my laptop on plug in. anyone know how to manually remove the driver package? also have tried safe mode to find package now , but no luck UPDATE: Okay it works in safe mode and can connect. and all i did however see it want to connect via com4 in safe mode and that is the same port as intel active management connects on. dont know if this could have an effect , going to see if i cna change port in safe mode to another port and see if it resolves my issue UPDATE 2 Great success , changed port to com 5 and now i no longer get the BSOD and it works without having to be in safe mode. now lets hope updates dont break this ./crossesfingers
  8. I also have came across this issue , so far only on my laptop thankfully Lenovo x220 i5 cpu windows 10 x64 pro It is happening with my reuleaux. the error that i get thrown up is "IRQL is notless or equal" Anyone have any idea? have already uninstalled escribe and same issue. also removed all other usb devices and same results. have tried two versions of escribe 1.0.32 and 1.0.35.2 and same results. my home pc is windows7 x64 pro and has not any issues with connecting. would like to get a fix on this as i travel a lot. UPDATE EDIT: I think it has to do with "windows driver package dimensions engineering" as my PC is fine when installing escribe , and UAC pops up and i waited a while before clicking yes and the moment I hit yes BSOD and now I can not reinstall package so I can remove it and it does not show in my installed programs anymore. but still crashes my laptop on plug in. anyone know how to manually remove the driver package?
