Couple of Escribe Suggestions 1. First time you plug in a new device, it should ask you if you want to save the settings as a default. 2. Should Prompt you with "Are You Sure" when you click "Upload Settings to Device" for new users with an option to disable the prompt for experienced users. 3. Mouse over help is missing for the LED section
Hi I picked up an SMY SDNA75 and have been playing with EScribe. It's a great tool. Most of it is self explanatory but have a few small questions that I couldn't find in the manual. 1. The SMY SDNA75 has a default reddish color on the button. I changed the Firing color in EScribe to Blue and it works when I press the fire button but after I let go of the fire button the color turns red and stays on for a few seconds. Not sure if it's the device but is there a way in EScribe to change the color after I let go to Blue and also adjust the amount of time the Fire Button stays on like you can with the screen? 2. What does "Normal Operation" do under Theme\LED section? 3. What are the Left Arrows for on the Color Selection in Theme\LED section?
