Oh and I was having the same problem that the OP is having. My only issue is that I cant delete the profiles that came installed. I would like reload all of mine as I don't trust any that Lost vape has loaded.
Anyone with the Therion please do not use the 316L loaded by Lost vape, it is not correct. If you check the profiles loaded by Lost Vape the 316L,430 and the kanthal are all the same. Go to steam engine and down load the 316L from there and it will work perfectly. Also if you compare the 316L from Lost vape and the steam engine one you will notice they are not even close on the graph.
